riverfever
- Woodland Park, Colorado
After lifting an XJ, which way will the pinion rotate...up or down? I ask b/c on mine, it rotated up. I noticed under acceleration that the pinion will rotate upwards as well...further off setting the centerlines of t case and diff. and making vibes more pronounced. I'm still getting a local guy arguing with me that the pinion should have rotated down after the lift and that under acceleration the pinion will rotate down. Then he wants to argue that my shims are in backwards. I finally had him look while I pulled away so he could watch the axle rotate pinion up. If I flip the damn shims, it makes the angle worse. He says somethings wrong with the suspension. Can anyone offer anything? I have searched and Yucca Man steered me to the TW Driveline 101 site but it doesn't answer my question.
