- Charlotte NC
So, here is the story. I found out that this will likely be the last weekend I will have off from work for quite sometime, quite possibly through the end of November. As a cause of that I decided I needed one last overnight trip to URE. Well no one could really go on such short notice, so I gathered my dog and camping gear and drove up there late afternoon on Saturday hoping that CNICKGO would join me on Sunday. When I got there I was just putzing around debating on where to go for the night, so I decided I would just hit Rocky mountain loop from the Dutch John trail head and circle around it to find a place to set up my campsite. Well as I had stated it was just the dog and I and we hit the trail. About 1/4 mile into it I saw that the left hand turn that turns into a big muddy rut with a rock off to the side seemed pretty slick, so I goosed it a little and hit it. From there things went downhill...
Now obviously when you are in a rut you are at the mercy of the line that is drawn, well that line allowed the whole vehicle to shift directly towards that rock to my right hand side. As I hit it I heard a thud and then I came up out of the hole and I heard scraping, like I had a tire down and I was buried in the fender well...no big Deal. I kept driving about another 500 feet until I got to a safe point to pull off the trail where its level with easy access to get back on once I change the tire. I got out and this is what I saw....
Well sure enough, ya I had a flat, but obviously we had bigger issues here.
I had sheared the leaf spring clear off the front of the shackle...
Now as I had stated I was by myself! Lucky enough where I pulled over I could camp out easily and just wait until morning when Nick showed up so we could figure out what I was going to do.
As luck may have it there were 2 guys in a wrangler that came up from the other direction and were intelligent enough to help me devise a plan to at least drive it back to the trail head and have hopes that someone could bring a roll back...
first-We took 3 ratchet straps and wrapped them around the axle then tied them to the unibody, so that we could pull the axle forward
We then ran into an issue with the tire still rubbing and locked up on the fender.
To solve this issue, we took 2 rocks and shoved them behind the rear shackle to push it back forward. We then took 2 pieces of wood and placed them in front and behind the axle to hold the leaf spring down further to keep the tire away from the fender.
After doing all of this I was then able to limp it all the way back to the trail head!
I got back to the trail head, they wished me luck and they went on with there lives. I then tried calling some people, but with little to no cell service I just gave it up. As I was setting up shop for the night some more guys came over and asked if I needed help, so after I explained what happend they extended the offer to help fix it the following morning. Well again as luck would have it, there "just so happened" to be an abandoned XJ near 109 that was left for dead that Saturday afternoon. I was stoked to be able to go see if we could fix it.
Well the next morning after assessing the damage and changed the flat. I tried contacting Nick with no luck via phone or CB. I then left my post and started limping the jeep towards 109 in hopes that leaf spring was still there.
While driving down the service roads to 109 I drove passed the guys that offered to help me fix it! They were still up for it and decided to follow me down there.
Well 1.5 hours later and about 2 gallons of water sweated out I had the jeep back on the trail with a nice gangster lean! hahaha.
Wheeled all day Sunday with no issues and drove it home!
After cleaning all the mud off I have a damage list.
Leaf spring (obviously)
RF tire-junk (hole in side wall)
RR tire-O.K. Chunk out of sidewall and a bent rim
LF tire-slow leak (already had it)
RF SPARE-2 nails sticking straight through it.
Front pinion seal is now seeping
swingout broken along with CB antenna (again)
Now because the XJ is leaning so hard on that RR the steering wheel is about 90* left and I can not hook up the LF sway bar link because its so hiked up.
In conclusion, during my time away from wheeling, I need to save up some money and fix this pig!!!
