Performance Ignition Question...
Culinary_Hooligan
Georgia
Hello, everyone, New to the website.... love it
my question is, Has anyone had any experience with the Screamin Demon coil kit offered by Performance Distributors. com? I looks like a nice kit, 10 mm wires, hi po coil, Cap with brass terminals (not aluminum), rotor, and (i believe) a set of plugs...
it' retails for about 170 bucks (for everything)
I though about going with the Nology plug wires ( supposed to help generate a spark 10 times hotter than a standard wire and plug set. Each of those wires has a built in capicator to insure consistent discharge...
Any and all thoughts on these possibilities will be greatly appreciated
The stock ignition system on the XJ is already very good. A set of Magnecor 8.5mm plug wires is probably the only thing you need. All other ignition components can remain OEM, including the Champion copper plugs.
