I briefly considered that this could be because of the lockout switch on the drivers side, but I'm not positive. Here are the symptoms:
Passenger side power window swith does NOT activate the window up/down.
Drivers side window switch DOES activate the passenger side window up/down.
The Passenger side door lock button IS illuminated with lights on.
The Passenger side power window button is NOT illuminated with lights on.
I wouldn't imagine that the lockout switch on the drivers side would cause the illumination light to turn off on the switch. The weird thing is that before I took the door panels off, it all worked fine. I pulled them off to replace speakers, now when plugged back in, I'm presented the issue described above.
Just wondering if you folks had any ideas?
I need to find a schematic to see if I am getting power to that switch, searched a bit, but didn't find one.
Thanks!
Thanks!
