tonofclay2
- Clovis, CA
Finally got around to disassembling CopperTop.
For sale are:
99 4.0L
The Good:
Head was milled down during a head gasket replacement for slightly higher compression. During that time the entire head was cleaned, the valves re-seated, and all gaskets including intake/exhaust, valve/head replaced.
This head job was about 2k miles old. New water pump, new balanced thermostat, and intake manifold/TB were cleaned to a shimmer. 103k miles on motor. I always did oil changes every 3k, had no cooling issues, and absolutely would have run forever.
The Bad:
I was in an accident which resulted in a rollover. The computer is bent, prob inoperable, the power steering pump was demolished, and the two breather hoses on top of the valve cover were broken.
The Ugly:
I painted the top of the valve cover Burnt Copper! Hence the name, Its sitting in my shop looking ugly, buy it!
Lets start at $500, obo.
Also have the gauge assembly from the dash, seat belts, and airbags which weren't deployed due the type of accident. Column is intact, steering box works.
Just make me an offer on this stuff, I know airbags can be expensive but I just want them to go to good use.
Clayton
For sale are:
99 4.0L
The Good:
The Bad:
The Ugly:
Clayton
