parts will be availible as of 2/15 it will get wheeled at Lobsters on the 13th then ill start tearing it apart the 15th, condition of some parts may change before then
RE superflex Lower Control Arms got some scrapes from wheelin and need frame end bushings replaced-75
RE superflex adj Upper Control Arms in great shape, flex joint was rebuilt in spring-100
Dana 30 3.55 gears, lockrite, comes disk to disk may include spare set of shafts-$200
RC 3" Coils-50
RE twin tube Frt Shocks for 2" lift-50
used RE Rear Brake Line-25
33x12.50R15 Good Year MTR's mounted on 15x8 AR steelies 3 have 40-50% trad 2 have 50-60% tread, spare is tubed due to slash in sidewall-400
Frt Driveshaft-20
Rear Drive Shaft new ujoints and yj slip yoke-25
custom HD crossmember withTcase Skid-100
hd Tierod, 1.25" 5/16 wall dom tubing and 5/8 hiems-100
rear axle is sold, motor trans andd tcase im keepin, all body panels are pretty much destroyed, does have full gauge cluster with 203k and most interior
all stuff is located in Keene NH and pickup only
RC 3" Coils-50
Frt Driveshaft-20
