TortureTested
- In my XJ
I was wondering if someone could describe to me the difference between part time and full time 4wd??
TortureTested said:I was wondering if someone could describe to me the difference between part time and full time 4wd??
ehall said:Full-time 4WD means that you can keep it in 4WD all the time if you want to.
Part-time 4WD means that you can only use it some of the time, and you cannot keep it in 4WD all day every day.
falcon556' post above explains why this is so
Meanwhile you can keep full time all the time regardless of the terrain.You can keep part time all the time if the terrain allows it.
Serveck said:is there any difference in gas mileage between full time and 2wd? if there was no difference i would run full time more often, but i never did a test. anyone know?
Hypoid said:Somethign to keep in mind about part time: When you are driving on slippery roads at relatively higher speeds (>30) the part time will CAUSE your tires to break traction where full time won't.
Do some experimenting with this in a safe place. My introduction to the phenomenon included a change of underwear.
kennzz05 said:ok so stupid question... could ya just swap a 242 for the 231 and get full time? be nice im sure its a dumb question thanks... ken:nono:
