- sacramento
trying to help a buddy figure out crappy brakes. Stock gears, 33s 2000 XJ, no ABS, stock master and booster. we replaced calipers, pads, rotors, hubs, front brake lines, and Master Cylinder. Replaced rear springs, adjuster kit, shoes, drums and wheel cylinders. Bled the hell out of it. No air anywhere. We welded up the divits in the caliper slides too. Brakes still seem pretty bad.
We figured as a last ditch effort to replace the proportiong valve.
All I can find is the mopar 52128420AA which are 186$, so was looking for a cheaper option. There are tons of cheap prop valves for the 86-96 which is interesting. Curious if anyone knows of anything other than the 186$ mopar ones.
we have adjusted the rear brakes many times too. first thought was they might be out of adjustment but doesn't seem to make a difference.
pedal feels good just doesn't like to stop.
The only other thought I have is to double check the caliper slides to make sure we ground them flat 100%. I know we ground them pretty good and flat, but maybe there is a little hump there. The divits were pretty bad.
