SteveX82
- Beachwood, NJ
It looks like I may have narrowed down the source of my problem. I pulled pin A24 from connector C1 and plugged the connector back into the PCM. No voltage was seen at either end of the BK/DG wire, but I was able to verify that the PCM's corresponding pin for A24 was reading 4.23v.
Before I start searching for a new PCM, can somebody positively verify that I should not be seeing ANY voltage generated from the PCM at this pin with key on, engine off?
