Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Well that's something good at least, although I thought I read somewhere LTFT should be less than 10%?
If the data looks good on gasoline and it's an LPG specific problem would that rule out faults that would be noticeable/common to both fuels such as manifold leaks???
Yes it might rule out manifold leaks, but a manifold leak, might be more obvious with one fuel than the other, as the LPG is not under control of the O2 sensor / PCM after all, from what you were told! Seems the PCM can not control the LPG with O2 sensor data as it is not set up to do so.
IIRC I read one site that +/- 5% STFT and +15% LTFT was normal, but I have not read up in detail on that!!!! The +15% LTFT was in a link a posted below, but I posted other good site info I have not had time to read cover to cover!!! YET! I do know, that I need to read more on LTFT, and what it really is and what it really means!!! Idid get the impression that LTFT was a long term number, like from cold start to hot operation, so it would be a bugger number, while you want STFT to minimal, which is +/-5% it seems?
