Ecomike
NAXJA# 2091
- MilkyWay Galaxy
What I'm interested in is what the "fuel trim" #s are. There will be two numbers the 'short term' (many times condensed into STFT) and long term (LTFT). They may give us a clue as to whether the lean condition is intermittant or constant.
The freeze frame data is a helpful tool because it gives you many of the operating parameters necessary to recreate the fault in the shop.(engine temp,engine speed, fuel trims,vehicle speed,things like that)
From what I gather, your software doesn't provide this. Hopefully I'm wrong.
As for test driving, Yes drive it with the laptop connected. If it's available use the software's "snap shot" or "movie" or whatever data logging functions it has to look at the failure after the fact. Otherwise you'll need someone to drive while you watch. Good luck and keep us in the loop.
I agree, the STFT and LTFT will be the one to watch here.
I think the ECU/PCM records the freeze frame data when it generates a code, so it may not show up on his software until a new code is generated. But I would rather see live dynamic data at various operating conditions, than just freeze frame data. I find freeze fram data alone very limiting.
The easyobdII software is what we were, are using here IIRC. I will check later to be sure.
I am curious what E-header you installed? OEM or something special?
