I am tired of fighting this, and spending money on it, if i cant fix it the ac comes OUT.
Heres the deal:
1995 XJ--4.6 stroker
new fan clutch
3-core gdi rad 2 yrs old
180 thermostat 1 yr old
water pump 1yr old
50/50 mix water-A/F new
newer style aux fan---seperately wired for when ac is off
hood vents
new rad cap
rad and ac heat exchanger have been cleaned(you can see right thru them)
and i built an adj. MAP sensor to deliver more fuel but with no good results(temp wise).
My junk will run around 180-200 with the ac off and aux fan on with 90+ temps.
With the ac on it's over 235 on the head and 210-220 on the block(aftermarket temp gauge).
If i make a run down the highway it'll hover 200-220(normal) as soon as i get off the highway and stop at lights it starts to rise over 220.
It has not boiled over yet but im not taking the chance!!!!!!!!!
I am at my wits end with this.
PLEASE help
Thanks STROKER
Heres the deal:
new fan clutch
water pump 1yr old
hood vents
new rad cap
PLEASE help
Thanks STROKER
