Alright... still having issues (duh)
So yesterday I put in a new thermostat (195*f Mr Gasket Balanced) and put a new sender unit for the dash gauge (just so I can be sure it's not off... (but the gauge itself could be off I realize)). Still have not replaced the cat though.
After that I left it idling with a shirt over the radiator to try and limit the flow... With A/C on and diff combo's, and it never got to 210*f. Idled for a total of around 1 hour. I held it at 2k rpm for about 3-4 minutes...
Now I drove it today, agreed in a hotter temp (80-100*f) over two hills. Almost the whole time it was at or above 210. Got to about 1/2 between 210 & the red on both hills. This is doing maybe 50-55mph.
Now I was thinking, maybe the Transmission is adding all the heat to the radiator thus it not being able to cool. So I was thinking about pulling the transmission fluid from going into the radiator, and have it only go into the auto-transmission cooler only. Then I realized if it's already adding that much heat with both, the little cooler probably wouldn't be able to cool it by itself.. (correct?) Now this is just a shot in the dark, but the radiator is now leaking transmission fluid (and I think the radiator is out of warranty, but I'll have to check later). So it kinda solves that leaking problem temporary..
So does the transmission add that much heat to the radiator?
BTW the transmission cooler is: B&M part #70268 - 19,000 GVW, 11'' x 7.5'' x .75''
