- Southern Maryland
This is for your 92Can anyone point me to a diagram of how coolant flows through the 1992 XJ cooling system? This system has the unpressurized overflow tank unlike earlier systems. I'd like to understand what drives water through the cabin heater core and how the heater control valve works.
The water pump pulls cold coolant from the radiator and pushes it through the block and head. From there it hits the thermostat housing, which has one hole that returns to the radiator through the thermostat, and another hole for the heater core circuit. Since the coolant has the pump pushing it (and fluids don't compress) the coolant goes through the path of least resistance (or both paths if they have similar resistance). Coolant that goes through the heater hose hits the valve, which either returns the coolant to the pump or directs the coolant through the heater core before returning to the pump (the valve is only open when the cabin temperature slider is set to HEAT and the blower is on). Note that coolant in the heater circuit does not pass through the radiator, instead the hot coolant simply recirculates through the motor. The design theory is that this helps to bring the engine to operating temperature quicker and the thermostat will open whenever the coolant gets too hot. The theory posited in this thread is that closing the circuit forces coolant to circulate through the radiator all the time which results in cooler engine performance.
