Hey,
My 94 XJ is overheating little bit on idle. It would reach to about 220-240 degrees. But if I put it in neutral and rev it up at any speed higher than idle (1300+ rpm), the temp gauge quickly goes back down to 190-200 degrees where it should be. The clutch fan seems to be blowing really good and when its off, I can still turn the fan by hand and still shows signs of some resistance. I think its fine. So I am wondering if my water pump is going bad or my belt??
Thanks.
Thanks.
