CleanInstall
- Allen, Texas
alright, I have a 94 xj with a 4.0L/5spd. 132K on the odo. I have been having some trouble with it getting to the 240-250 degree range when it's not moving.
I replaced the waterpump with an AZ unit(yeah, i know) about 25K miles ago.
When the radiator started to leak this past winter, I replaced it with a supposed modine from napa(it fit kind of crappy and the box said GDI somewhere in smaller print). it had run a little warmer this spring when it started to warm up, but now it's getting bad.
I threw a 160 degree t-stat in there to try and band-aid the problem for now, but since my problem is overheating at idle, this doesn't work too well.
I had been running just straight water in it like a dumbass, so there was a lot of sludge, even after a couple of good flushes, it's still looking pretty rusty and nasty.
just replaced the fan clutch today to no avail with a napa clutch(which out of the box seemed to spin pretty freely, at least a lot more freely than the stock one.) however on my oem clutch the little thermal coil was pretty gunked up, so that may have been the problem with it. it still has no problem getting to 240-250 degrees while idling. this i'm sure will perpetuate my oil burning problem. so it's no good.
I really just want to rip out all the replacement cooling parts and start again with the high dollar stuff, but if there is any way to salvage the current cooling system, i'd like to try. I definitely want to know the best way to flush all this nasty coolant out of the radiator and motor(maybe using a steam cleaner somehow. any suggestions are welcome and I apologize for the lengthy post.
P.S. other than this problem, the motor seems to run well and it will pull about 13-14 mpg with a 4.5inch lift and 33's on stock gearing(4.56's in the form of an 8.8 are in the works this summer
