The way I've always done compression tests is to disconnect and ground the coil wire if so equipped or disconnect the coil pack connections, and then unplug the electrical connections to the injectors--(don't skip these steps), with carb cleaner and compressed air blow out the area around the plugs to remove any dirt or other crap that might be blown into your face/eyes and/or sucked into the cylinders. Wear safety glasses.
Remove all the plugs (lets the engine get to several hundred RPMs), brick or a stick between the seat and the gas pedal to hold the throttle body valve all the way open. The battery should be fully charged (~12.6V with the engine off) or hook up a good battery charger.
Then run the test (crank the engine for a few seconds with a remote starter or helper) as is (dry), note the figure then squirt some engine oil in the plug hole (wet) and note the reading. If there's a big difference between dry and wet readings it could mean bad (worn or broken) compression rings. Bad readings between two adjacent cylinders could mean a bad head gasket.
If your numbers are OK you could do a “Leak Down” test with the cylinders wet; bad numbers here might indicate bad valves. Let’s hope for the best.
There are different guidelines from different manufacturers but as a "rule of thumb" the readings should be about 10-15% between cylinders. I'm not sure what Jeep says, but I'm sure someone will chime in. Get back to us with your numbers.
^^This is good advice.
ALL of the plugs need to be out to run the test as the engine needs to be able to crank at full speed. You can disconnect the coil by unplugging it from the harness.
If you do not have a compression tester, get one that screws into the spark plug hole and has an o-ring on the connector to seal it.
Run all of the cylinders dry. Then squirt some oil into the cylinder to be checked wet, personally, I like to use a 5w engine oil. Crank the engine through at least two compression cycles to distribute the oil in the cylinder and then check it with the compression tester.
Here is the official Jeep approved method for a test:
<<FSM QUOTE ON>>
1. Clean the spark plug recess with compresses air.
2. Remove the spark plugs.
3. Secure the throttle in the wide open position.
4. Disable the Fuel System.
5. Disconnect the ignition coil.
6. Insert the compression pressure gauge and rotate the engine with the engine starter for three revolutions.
7.Record the compression pressure on the 3rd revolution. Continue the test for the remaining cylinders.
The specs for a good engine are:
Pressure range...827 to 1,034 kPa (120 to 150 psi)
CYLINDER COMBUSTION PRESSURE LEAKAGE TEST
The combustion pressure leakage test provides an accurate means for determining engine condition.
Combustion pressure leakage testing will detect:
* Exhaust and intake valve leaks (improper seating).
* Leaks between adjacent cylindres or into water jacket.
* Any causes for combustion/compression pressure loss.
1. Check the coolant level and fill as required. DO NO install the radiator cap.
2. Start and operate the engine until it attains normal operating temeratures, then turn the engine off.
3. Remove the spark plugs.
4. Remove the oil filler cap.
5. Remove the air cleaner.
6. Here the FSM says to calibrate the tester we can't do that... But it does say to run between 70 psi minimum to 200 psi maximum input pressure. So, shop air works.
7. Perform the test proceedure on each cylinder per the manufacturers instructions.
While testing,
listen for pressurized air escaping through the throttle body, tailpipe and oil filler cap opening. Check for
bubbles in the radiator coolant. All gauge pressures should be equal with no more than 25% leakage.
FOR EXAMPLE: At 552 kPa (80 psi) input pressure, a minimum of 414 kPa (60 psi) should be maintained in the cylinder.
CYLINDER COMBUSTION PRESSURE LEAKAGE DIAGNOSIS CHART
Condition.
Possible Cause. Correction
Air escapes throughThrottle Body.
Intake Valve. Inspect valve and valve seat. Reface or Replace.
Air escapes through Tailpipe.
Exhaust Valve. See above.
Air escapes through Radiator.
Head Gasket leaking or cracked head/block. Remove cylinder head and inspect. Replace defective part
More than 50% leakage from adjacent cylinders.
Head Gasket leaking or crack in head between adjacent cylinder. See above
More than 25% leakage and air escapes through filler cap opening
only. Stuck or Broken rings: cracked pistons; worn rings and/or cylinder wall. Inspect for broken rings or piston.Measure ring gap and cylinder diameter, taper and out- of-round. Replace defective part.
<<FSM QUOTE OFF>>
So, what you will need to make is a tester or, go have it done. The tester has a gauge, a connector to screw into the cylinder head, a valve to shut off the incoming air pressure and a schrader valve so the pressure can be dumped at the end of each test. Not difficult to make.
Here:
http://www.google.com/products/cata...T76CBY2DsAK9xsGRCQ&ved=0CHoQ8wIwAA#scoring=tp
is a quick web search. You can get one for under $75, or... Look at the picture and build one.
Hope this helps.
