ORGS supernerfs almost done but.....
CStamm
Leeport, PA
Ok so I am almost done installing my supernerfs. I got the new style, which has less of an angle from the square tube to the outside round tube. They also came with a template that you line up on the pinch seam in order to drill your holes, very nice.
I had to beat on the bottom of the rocker in order to get the holes to line up with the threaded square tube. I am stuck at drilling the legs to the frame, as I have no right angle drill (yet). I lined up the legs as they are supposed to be, but in order to get the bottom holes to sit up high enough to drill all 4 holes into the uniframe, I have to jack up on the leg portion, to rotate it up. Is this how they are supposed to be? Anyone else run into this? TIA, sorry for the long post.
Yes, use a jack under the leg and have the base plates go up as far as they can, or enough to get the holes drilled into the frame. You can adjust this part a little to line up the 2x2 and outer tube to where they look good. You really don't need a right angle drill just drill as straight as possible and then install the bolts, just do over tighten them.
HTH
mark
HTH
mark
hinkley, let it go man.
that's jim's post yer answerin'.
:wave1:
Hinkley, if you're bored, you can consult on customer questions on URF products.
We're always looking for patient, friendly, customer service reps. ;)
CRASH
Mark Hinkley said:
Still my joooob man!
hinkley
Mark,
Thanks alot, I was hoping you would chime in. I figured that was the only way to do it. Thanks again, awesome product.
