What Rd
- Athens, IL
My 93's steering column loosened up to where the wheel was flopping around pretty scarily. You guys steered me to a couple of web sites with instructions on tightening up the column. I did it. It sucked. After all that work (made all the worse by the need to also remove my hand controls and CB radio to get the necessary access), I was only able to get a fair grip on the two semi-accessible bolts and get them semi-tight. It's already starting to loosen up again, and it's only been two weeks.
SO, I'm looking for other options. I don't relish the idea of taking the column completely apart to get access to all four bolts, but don't know what my other options might be. I'd be skeptical of swapping in a used column that may not be any better a few weeks afterward. I need to retain the tilt feature, as well as the bright/dim switch on the column, but apart from that I'm fairly open to suggestion. What options can you guys offer?
TIA.
TIA.
