outlander
- Columbus,Ohio
DEATH TO ALL GREEN TURTLES!!!
I just got around to doing the poor mans open cooling system conversion and I can tell a difference in the temp right off the bat.
I first went to jegs and bought myself one of these:
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_14068_-1
Then I stopped by advance auto parts and picked up a radiator cap for a cherokee that has the open system.....91+ I believe($5.99)
I mounted the filler neck just like this article details:
http://www.jeepinjoe.com/XJ_Tech/Open_System_Switch/open_system_switch.html
I didn't have to grind anything,though:dunno:
The only difference is in the interest of doing this as cheap as possible....which meant retaining as many original parts as possible(including closed system radiator),I used a heater hose repair kit to connect the hoses that went to the closed system surge tank(which obviosly gets tossed)instead of buying the different heater control unit or valve.
like this(click to enlarge)
Using the plastic heater hose repair kit tube,place it inside the smaller hose secure with hose clamp.Then slide the bigger hose over the smaller hose and secure with another clamp.
I do however need to get an overflow tank....it hasn't been a problem as of yet.
I'm very happy with this way of doing this conversion because it is very cost effective and easy to do....I have about $35.00 invested in it and it's like night and day.The closed systems " green turtle" wasn't holding pressure causing me to boil over.No more boil over and I can swear that I run cooler also,and thats always good.
