More progress..
Finishing the roof.
I think this will hold.
I don't think these straight tubes down the center add much strength, but I wanted to be able to throw a spare tire, etc. on the roof for very long trips. They're really just mounting supports.
Capped off the ends of the tubes.
Cutting plates for both above and below where the tube meets the floor.
These little plates will be welded to the roof where the tube comes through to keep the water out.
The plan was to drop the cage in, tack it in place, then lift it up a few inches to fully weld. Unfortunately we couldn't lift it very far, probably because the tubes enter the cab at an angle. We resorted to this.
These plates will be bolted through the floor and then to the frame, but he stitch welded them to the body for now. Not sure how useful this is. The sheet metal on the floor is very thin. The undercoat on the other side caught fire a few times.
Shoulder bar goes in.
Ready for some triangulation in the interior.
I was stoked to drive it home even though the cage isn't done.
We still need to finish the interior tubing, tie the floor mounts to the frame, tie in the cowl add tie down points inside.
