One of them hybrid cage builds (lots of pics)
travisk
Fullerton, CA
Not just any fool can build a hybrid exo cage on his XJ, so I hired my friend Kalil to help me build one. He's new to Jeeps, but he's fabbed some really nice cages for his Ranger bros. Surely nothing can go wrong.
This design is definitely a compromise between added passenger safety and protecting the unibody in a low-speed flop.
Here it is, in pics:
I picked up seven 22' sticks of 1.75" .120 wall DOM tubing for $2.60 per foot. i'm pretty sure we won't use 154 feet of tubing, but better safe than sorry.
First I spent a few hours stripping out the carpet, plastic pieces, seats, center console, headliner and front fenders. This is the part where you realize how insignificant the amount sheet metal is protecting your head in a Cherokee.
Kalil started on the halo. There are 4 bends up front. Bending an 18' tube indoors was a challenge. We had to move a lot of things around the shop and flip the bender around a few times to get it done.
The halo came out pretty good, but we ended up cutting it and slugging it up front to get the width and shape exactly how I wanted it.
I'm told slugging can be just as strong as keeping the piece whole, so I'm not too worried about it.
Four bends in each of the three spreaders.
It took a while to get the notches in each of the spreaders just right.
Running a 2" hole saw through layers of sheet metal with a high-torque drill was good way to almost break my arms. No turning back now.
Lots and lots of notching.
Getting the fit right takes a while.
Getting the cage to hug the roof fairly tightly is a priority for me.
Kalil tacking in the spreaders.
B and C pillars are set in place.
The B pillars hit 6" plates at the floor, which will bolt through to plates underneath that will be supported by a very short tube to the rock slider support, which is welded to my frame stiffeners.
Continued...
C pillars go up behind the back seat. They will bolt through to plates under the unbody. I'm not exactly sure how I want the bottom plate to attach to the frame rail yet.
Trying to get the halo to fit just right.
The end of Day 1
Tomorrow we will lower the front a bit, do the A pillars, weld it all up and start on the triangulation.
As always, any critique is appreciated.
looks good so far. hard to make critiques until it is done.
and plans to cross-brace the B or C pillars? cowl spreader?
Yes. B pillars will be tied together with a standard shoulder bar and 4 diagonals meeting at the center. C pillar will be triangulated back down to the no-lift shackle mounts where they come through the floor.
On the roof, there will be tube from the center of the first spreader to where the A pillar meets the halo, and another pair back to where the halo meets the C pillar.
IMS quoted me $2.30 a foot, but driving with 22' pieces was sketchy enough without getting on the freeway, so I kept it local at Benner. I had to triple check that they were quoting me DOM prices because it was hard to believe.
most steel places will deliver for a very small fee.
one of the reasons I have been paying $3/ft for 1.5" and $3.50/ft for 1.75 is that particular supply delivers for free.
looking good!
The B and C pillars look nice, got them tucked up to the body pretty good. Looking forward to seeing how the A pillars come out. Are you gunna tie the halo into to factory dip rails at all? I have mine welded to them all the way around and it really ties everything together
Looks good. I should check tubing prices locally. I just gave 4.79/ft for .120 1.25" 4130. DOM should be cheaper. :) How you going to tie in the A pillars? This is exactly what I'm looking at doing. I'll start with a 2x5 or 2x6 rocker replacement to have landing spot for the A pillar. Erics XJ style. Oh, when you do the A pillar, make sure to leave room to change a windshield. :)
A pillars will go down the inside of the fender just in front of the hinges and connect to the rock sliders. They will also weld to plates on the side of the cowl. I will forgo a cowl spreader right now as it doesn't seem necessary.
We put in another 4 hours today.
Strapped the cage down tight to set up the A pillars.
It took a while to get these notches just right.
Kalil is meticulous about getting the fit just right.
Ready to tack the A pillars in.
All set. The A pillars run down the inside of the front fender into the rock sliders.
The first triangles are formed.
Brought the cage inside for the next set of angles and to weld it all up.
Nice and tight
He put a lot of effort into getting these just right.
Tomorrow we'll finish up the roof, weld it up, put it back on the jeep, weld it in and start on the internal triangulation.
Looks great, now when you get done with it let me know so you can get it installed on my jeep.;)
Thank You
It is going to be nice when you finish. Looks great
lookin real good! subscribed because ill be using this thread as inspiration when I do my cage
