Ok would these Tires fit?
4x4forfun
i have a stock 1998 jeep Cherokee 4x4 its running 225/75/15, i need to replace the tires on it i was told that 31x1050x15 would fit. After sorta test fitting one to the car it looks like its going to rub in the front, when i turn. the tires i am looking at are bfg A/t or M/t. any help would be great.
I think 30" tires is the limit on a stock XJ without trimming. My 32 inch BFG ATs rub just a little with 4.5" of lift.
31's will rub LCA's on flat ground and fenders while flexing.
this is 31's on 3" lift.
Throw on a cheap 2" budget boost (coil spacers and leaf shackles) and then it will fit ok.
