ColoradoRaptor
Headbanging Hillbilly
- Canon City, Crawlorado
Check your temp sensors!
Troy,
Have you inspected the butterfly to see if it's installed correctly? Yeah ir sounds kinda stupid, but there is a beveled edge on two different sides of the butterfly. Can't hurt to pop the air tube off and have a close look. Hell I'd try swapping the throttle body off a properly running rig at this point.
I know you've used carb and choke cleaner to check for vacuum leaks, but I'd suggest using propane instead. It will cause a very audible increase in RPM's.
My money would be on ground wire gremlins. The brakes dump a bunch of voltage to ground for the brake lights, and a poor ground connection(s) can back feed into the TPS / ECU grounds and cause idle annomollies big time with Renix. They seemed to have solved the problem in the 91.
I'm having the same issue, new IAC, new tps , new exhaust manifold, my rpms at the obd2 port are different than the tach and the tach is right, you figure it out let me know, I'm headed out now to find a used pcm
