Gunter
- Aurora, Colorado
again....it is dead and no chargy. wtf??
so i have continuity with all my grounds, IE they all work. checked with Ohm meter.
i have all the usual functions , IE all the lights and all the horn etc are working.as i cleaned up the grounds,all the non working lights etc came back and work as intended.
the alternator when it was working, made 14.25 V and 6.5 A on the fluke multimeter.
the battery takes a charge when the alt works.
both are new.2 weeks old.
now today the alt wont charge--
i HAD a semi cut and corroded wire on the plug to the alternator. i got one from the junk yard and wired and heat shrunk those repairs, soo all is sealed.
either i have one of my repaired wires ****ing me up--
or a bad alt right off the shelf.
the alt plug, the wires are one to excite the field,and i guess the other is for the dash light? and when the alt was working, the dash light was working fine and still does. as the engine starts, the light goes off. if the alt stops charging,shouldnt the light come on?
monday i had a wierd screaming noise from the truck...maybe a stuck alt brush?
i am going to tap the alt and see if the brush is stuck and if it releases.
then check the plug to see if it has voltage on both wires.
if i cant get it to charge i am taking the new alt off and i had the old one tested so i know it works now..
then see what my numbers are. damn i hate this !!
