1bolt said:
Not trying to question your nearly encyclopedic knowledge of the 4.0, but I'm curious where you found out about the nickel content? I'd love to read it, is it from one of the mopar engine books?
The lightening was to reduce the _amount_ of iron and weight of what is one of the heaviest per cube gasoline engines in production in the last decade. The 4.0 weights more than either ford or chevy late small block V8 (302 or 350, don't know about the 4.6 modular).
Considering the power output and the RPM range there's simply no reason for it. How rare is a cracked 4.0 block of any vintage? Pretty damn rare in my experience. I can't give away 4.0 bare blocks.
Lastly NVH was done by stiffening... primarily with the crank girdle but also with changes to the internal webbing and improvements in casting technology (read; more consistently in tolerance, less core shift, more consistent wall thickness).
You can't reduce NVH by weakening an engine block or lightening it... Quite the opposite, to reduce vibrations requires stiffening the block; In key areas that are most likely to reverberate noise, or become the source of noise... Not coincidentally those key areas are also likely to be the weakest surfaces of the engine block, longer planes and angles that can vibrate most readily. A nice side effect of reducing NVH is that those same area's are made less weak with more material or better engineered structure (webbing).
The implication I draw is that the newer blocks should be both lighter AND stiffer, if they flex less, that ALSO means they will last longer, and they will stay straighter, their cam shafts (and bearings) will last longer. If they have poorer iron then the sacrifice will be more wear in the cylinder bore..
I'll have to dig through my notes - but I note that AMC was fond of high-nickel iron alloys, while the only real high-nickel "Big 3" castings were for the second-generation 426 Hemi.
While the later 242 blocks may be stiffer (and lighter - the first NVH revision dropped about 50 pounds, with another 20 or so at the second,) the reduction of the nickel content of the alloy actually makes them
less tough, not more. Toughness in an alloy has more to do with the chemical composition of the alloy - and a high-nickel iron is both "tough" and resistant to abrasive wear (like with piston rings.) However, increasing the nickel content usually costs more - which is why Big 3 beancounters don't like it.
As far as where I got the information, I think it was from a combination of research into AMC vice Chrysler production - as I said, I'd have to check my notes (and I'm working on something else at the moment, so it may take a while.) I doubt it's apocryphal - I've been wrong before, but this seems too "fixed" for it to be a mistake on my part (and I do know that at least the early blocks had a relatively high nickel content - I haven't had an assay done, but I've seen how they wear, and I'm much impressed.)
And yes, the 242 is a relatively "heavy" engine - both in pounds/cubic inch and pounds/horsepower (a fully-dressed AMC242 weighs in around 550#, so you're looking at about 2.27#/ci and, for RENIX, about 2.97#/fhp, assuming RENIX at 185fhp peak output. Engine pounds/foot-pound of output would be slightly lower.) However, even the traditional small block engines (Chevvy 305/350, Ford 302/351C/351W, Chrysler 318/360) were revised to accept aluminum cylinder heads and aluminum heads have been available in the aftermarket for years - while the AMC six has just caught up as of about six years ago (they came around shortly after I tried to talk to Russ Flagle about the idea, as a "Strokers" emissary, around FEB2002. I was heading to Indy anyhow...)
Those figures are also for a "fully-dressed" AMC six - meaning with all accessories, but "dry" (no fluids.)
There's no particular reason that the AMC six legacy could not have continued tho - BMW has been using inline sixes for just about their whole run, I think MBZ still uses them, Chevvy has brought them back in Vortec trim, and I'm wondering how long it will be before the Chrysler LG/RG series (Slant Six) gets resurrected... That was also a veridam good engine, and I've often wondered why it's not still around (especially as the Hemi Six that was used by Holden in Australia. I think it was Holden, anyhow...)
