Mine currently runs from 22 psi (HOT oil, 200 F, idling in park) to 60 psi (cold engine). I ran a thermal oil versus oil pressure test on mine and found that it takes up to 30 minutes idling with the A/C on, or a good 20 minute hard run on the freeway in the summer, to even get my oil up to 200 F. At 170 F I still get 30 PSI idling in park (about 550 rpm), but at 200 F it drops to 22 PSI idling in park. My oil takes 15 to 20 minutes longer than the coolant to reach peak temperatures. Oh, and at 150 F I still have 40 psi idling in park, even with my coolant already at 195 F.
I think it has a lot to do with the polymers they use nowdays in the multiviscosity oils too. There have been some discussions elsewhere about oil polymer additive shear problems causing low oil pressure.
I have 250,000 miles on mine ( but I have only owned it for 3 years, so I don't know the real engine mileage or complete history), running 20W50 plus 1 quart of Lucas. I also have a high flow oil pump and new crank bearings. If I run 10W30 it won't hold 10 PSI at 500 rpm in park with 200 F oil. The only bearings that were not checked recently were the cam bearings. The rest were OK. It does not use or burn oil.
Jeep spec is 13 psi minimum hot oil pressure in park at idle.
IIRC the oil pressure sensor is after the oil filter, so a clogged oil filter will show as a low hot oil, oil pressure, but does not show with cold oil.
