There aren't any hidden bolts, as all oil pan bolts can be seen from underneath. I just did a RMS replacement on my '98 this past weekend, so it's all still pretty fresh in my mind.
Some things I learned to make a RMS replacement easier. Once you loosen the pan, it can be a real pain to move it out of the way. Since I was also installing some drop brackets, I remove some of the front end components.
I removed the springs and unbolted the lower shock mounts. I then removed the track bar bolt at the axle end and move it out of the way. I removed the steering stabilizer bolt at the axle and also the passenger side tie rod end at the steering knuckle, and swung all that out of the way. I then lowered the axle down as far as it would droop, and I had all kinds of clearance to slide the pan out. It really only adds about an hour's time to move everything I mentioned, and made life easier overall. You'll otherwise spend at least an hour trying to jockey the pan out, and some folks actually unbolt the oil pump and drop in the pan for more clearnce, to remove the pan. Believe me, it will make reinstalling the oil pan a lot easier too.
Another trick I really liked when I went to reinstall the pan was to use some RTV and install the pan gasket to the bottom of the engine block. Apply a thin stip of RTV round the bottom of the block. You don't need ungodly amounts of RTV. Just enough for the gasket to stick to the block. Start from the back around the dip and begin pressing the gasket in place. As you do this, use some of the pan bolts to hold the gasket in place as you work your way towards the front of the engine. Go back and press the gasket in place really well and let it sit for a while. Once the RTV has had a chance to set, you can remove the pan bolts holding the gasket in place, then proceed to install the pan. I feel it works better than using the zip ties or rubber band trick to hold the gasket to the pan. What worried me about gasket to the oil pan aspect, is that if the gasket at the rear of the pan dip is not perfectly in place to meet the groove in the rear bearing cap, you're going to wind up with a bigger leak. At least my way you know the gasket is where it is suppose to end up on the block, and the pan will seat it the rest of the way.
Do search on how to remove and install the upper seal. Mine came out relatively easy by tapping it out. However, I was only able to push the new one back in half way before it became "stuck". At that point I loosen the remaining bearing caps just a bit, gave them each a slight tap with a hammer so the crank would loosen, and the seal then went in the rest of the way with litte effort. Just torque the caps to 80 ft lbs once you have the seal in place....
