Well, finally switched out my OFA gasket today!
14MM hex bolt confirmed for my 93' 4.0HO. Ended up needing a sledge and a 18MM deep socket to dislodge the 14MM from it's 1/2 inch socket casing. Taped it to a half inch wrench and then added the 1.5ft bar from my hydraulic jack to get the leverage to loosen it
after getting it off and replacing the gaskets, dropped the 14MM hex BEHIND the upper control arm bushing (Stock). So that was fun to get back out lol!
tightened everything back up, spun on my new WIX filter dropped in 6 qts of 10W30, turned it over and reveled in the absolute lack of oil seepage from the OFA....
Until i saw that the RMS is now confirmed leaking! However, 4 drops after sitting long enough to cool down is fine by me for now!
Went to align the toe-in and watched in dismay as my tie-rod shifted a solid 2 inches up and down (in the ball joints on both sides)
I guess that is what is causing all the play in the steering
time for the ZJ tie rod upgrade
Anyone ever wants to borrow a 14MM hex, 60 torx, 9/16 hex. PM me and i will USPS the bit to you!
