M md21722 NAXJA Forum User Location TN May 25, 2015 #21 The large adapter bolt is steel. The adapter itself is aluminum. Why not just went a T60 bit to a flat piece of steel? This job isn't that hard. If need be you can remove the bolt into the frame rail for the engine bracket.
Weasel NAXJA Forum User NAXJA Member Location Billings MT/Rapid City SD May 25, 2015 #22 I have a T60 with 2 flats on it but it fits loose in the bolt, so it want to tilt to the side when you load it.
