The simplest system is using a stock air box with a cowl intake.
http://www.flickr.com/photos/lwade/sets/72157622703531169/
It keeps the water out and provides cooler intake air.
Insulate everything you can.
Green Air filter.. better than K&N
Item # G512004
greenfilterusa.com
The round thing? Not sure, but if it is that, I'd like to remove it. Don't need cruise cause it doesn't work anyways haha! Only thing on the Jeep that doesn't work.
Clean, eh? I was kind of embarassed of it. Haha.
I will have to pull up th vents to see if there's anything under there that'll block the filter, but I don't think there is.
I think you're right. I'm leaning towards that build. I'll have to get a box from the junkyard, get a nice drop in filter, and the rest of the parts. The wrapping is just heat resistant wrap, right? What's the real term for it so I can fond it easily.
http://www.discountairintake.com/store/?Ntt=G512004&N=0
Part Number: 2004
Some also use a cone filter in the stock airbox in place of the panel.
I guess they changed the PN.. now the PN is 2004
[FONT="]
Use a good paper filter in the stock box. Here is the one I use.
Purolator PA24372
http://www.purolatorautofilters.net...264&yid=29&make=JEEP&model=Cherokee&year=2001
http://www.purolatorautofilters.net/products/air_filters/Pages/pureoneairfilters.aspx
I never see any moisture or dust inside the throttle body intake hose, a good sign that the air box and filter are doing their job.
I wrapped the air box and hose with thin foam rubber and covered with a cut up folding silverized dash sunshade. The seams are sealed with metal mending tape (from Lowes). In between the box and exhaust manifold, I installed a heat shield made from a dual-layer cookie sheet.[/FONT]
