Blazair
- Apple Valley, SoCal
Its a 3500 lb axle with 2500 lb springs.
(I dont ever plan on carrying 2500 lbs in it. Maybe 2499 lbs.)
Tongue is on... needs a few more little details to get it legal...
Curt
What I am wondering though is what do they use for the front of the trailing arm? What kind of joint do they use? What would last and be easy to repair?
Hey Curt. I hope you didn't cut up a perfectly good MJ to build a trailer! That thing looks good. Does this mean you are done playing with trailers and are going to do some wheeling?
Looks great!
Something I have learned with mine, you need to get as much weight over the tounge as possible. Mine likes to wander around when it is empty or loaded evenly, when it is loaded toward the tounge it pulls great. A tounge box or anything else up there would help out quite a bit.
Your tounge looks to be about the same length as mine. I drove mine around in the snow the other day and it follows the jeep almost perfectly. I have been able to sneak it around some pretty tight turns without having to worry about it.
The lock & roll hitch looks good on it, my pintle/lunette setup is pretty loud when the trailer is empty. I think adding tounge weight would help that out quite a bit as well.
Isn't it amazing how light these trailers seem when they are empty?! I can pull mine around with one hand like it is a little red wagon.
The rear tied into the rear of the frame...
Getting close to being towable...
Curt
Any thoughts of swapping the d35 for a trailer axle to reduce weight/increaSE CLEARENCE?
Here is a picture of my M100. havent decided if I am going to sell it or keep it.
http://www.ksl.com/index.php?nid=218&ad=5236815&cat=&lpid
Sold my trailer saturday. I am going to build one from scratch instead.
Looking for an indepth thread when ya get started. :thumbup:
Have a design your working on?
