A CO2 tank holds something like 800 psi of pressure. The CO2 is actually a liquid inside the tank and only becomes a gas as the pressure is released and it comes out.
As you may (or may not) know, a SCUBA tank holds compressed air at about 3,000 psi. The difference is significant. As all SCUBA divers have been taught, breaking the valve on a full tank turns it into a missile! I have seen this first-hand myself when a tank fell over, broke the valve off, shot a huge hole through the side of the boat, and went skipping off across the water doing a credible impersonation of a torpedo. Had anyone been between it and the side of the boat where it went through I have absolutely no doubt that they would have been killed.
If you use a SCUBA tank you must EXTREMELY careful about how it is mounted in order to insure that there is NO WAY for the valve to be damaged!
