talentjeep
- talent,or
So I've taken it apart and put it back together three times now. I've lubed everything with engine assembly grease. I've double checked and re-checked. Everything looks good. The snap rings are in, everything turns and is tightened up the only mod was I switched out for a '95 23-Spline input / upper (solid piece) shift fork into a '87 21-spline np231/.
I get it to shift but i tried rotating the front output shaft while shifting to see if it would assist since it wasn't ever slipping into neutral fully...now it's stuck. last two times i had it together it wouldn't shift at all.
does anyone have any special tricks? any helpful links? i've stared at the exploded diagram for hours with no luck. i must be doing something wrong and I know if anyone knows...you folks know...
thanks.
p.s. that is part #2 and part #28 from this http://globaldrivetrainparts.com/image/np231-transfer-case-parts.gif
thanks.
