Mike1331
- Folsom, CA
hack n tap, seal is brand new but the size was slightly off and it leaks probably 1/2 quart every 500 miles, i have two more seals. Shaft is welded to yoke as the tap broke, It needs a plug weld drilled out and it needs to be re-tapped. Probably take .5 of an hour to fix with it out of the jeep. Shifted great and i know i'll miss it for the snow. Comes with linkage that worked great.
Folsom, pick up only
call me or text
916-834-2836
call me or text
916-834-2836
