Mike1331
- Folsom, CA
tcase shifted flawlessly the whole time i had it. I found a 231 w/ a hd sye and tera 2 low so i'm running that.
One drawback to the tcase, is that i welded the tom woods yoke to the t case shaft becasue i broke the tap while tapping out the shaft. So it works but if you want to replace the seal you have to drill out the weld plug to remove the yoke from the tcase shaft. I ran a stock front shaft out back w/ this set up and it worked fine w/ 12"s of rear wheel travel.
My drivetrain: 87xj/4.0/aw4/d44
I'm in folsom, pick up only
Give me a call - 916-834-2836
