Np 231 with hd sye
1-tonxj
Colorado
Have this sitting on my trailer doing nothing...it worked as it should before being pulled for the Atlas .I think the chain may be getting to the need for replacement as I think it May have more play than it should it made no noise so it still has life in it but is certainly not going 50k before you put a new chain in...they are $80 new takes an hour or two to put in still in the jeep ...will come with the old style Novak shifter that eliminates the stock linkage
$100 .
i thought this was gonna be mine? you've gt my digits
Almost 2 months ago you said you were comming through denver on your way to foco on saturday you said to text you I did...do you recall the content of that confusing round of texting ...never an answered pm after .
Anyway while sitting I pulled the rear 32 spline yoke took the 1350 off yhe atlas and used the sye yoke to install temp 1310 shafts...you're welcome to the case as is I have no use need for it the case is just sitting minus rear yoke ..$40 without yoke .
