non-XJ - FS: Sony STR-DE897(Black) 770W 7.1 Home Theatre Receiver $100
djblade311
NAXJA Member # 1474
Mission Viejo
This Sony Home Theatre receiver is a STR-DE897(Black) 770W 7CH amp that is in PERFECT working order. This is an awesome receiver that I'm selling only because I received a newer receiver for my birthday. This unit comes with the remote and there are only some small cosmestic scratches on the top. See the pics and you'll see they are hardly visible. All inputs and outputs work perfectly and puts out 110W per channel.
More Info on Amazon.com or Sony.com
$100 OBO -
CALL ME if interested as I'm not able to check PMs very often.
773.three five four.6715
STRDE897/B 770W 7.1-Ch. A/V Home Theater Receiver specifications
General
  • Width 16.9 in
  • Depth 14.6 in
  • Height 6.2 in
  • Weight 0.4 oz
Enclosure Color Black
Audio Features
  • Surround System Class 7.1 channel
  • Amplifier Output Details 110.0 Watt - 8.0 Ohm - 20 - 20000 Hz - THD 0.7 % - 7.0 channel(s) ( Surround ) , 100.0 Watt - 8.0 Ohm - THD 0.09 % - 7.0 channel(s) ( Surround )
  • Sound Output Mode Surround Sound
  • Built-in Decoders DTS-ES Matrix 6.1 , DTS-ES Discrete 6.1 , Dolby Digital , DTS decoder , Dolby Digital Surround EX , DTS Neo:6 , Dolby Pro Logic , DTS-ES decoder , Dolby Pro Logic II
  • Surround Sound Effects Digital Cinema Sound EX
  • Digital Sound Processor (DSP) Yes
  • DSP Presets Cinema Studio Ex. B , Jazz club , Cinema Studio Ex. A , Live , Hall , Cinema Studio Ex. C
  • Input Impedance 50.0 KOhm
  • Input Sensitivity 500.0 mV
  • Response Bandwidth 10 - 100000 Hz
  • Signal-To-Noise Ratio 96.0 dB
  • Bass Control Yes
  • Treble Control Yes
  • Additional Features Pink noise generator , Source direct , A/B/A+B speaker switch , Digital signal format auto detection / auto switching
Inputs & Outputs
  • Headphone Jack Yes
  • Coaxial Digital Input Yes
  • Optical Digital Input Yes
  • Optical Digital Output Yes
Equalizer
Equalizer Yes
Tuner features
Type Radio tuner - AM/FM - Digital
Tuning Display Fluorescent display
Preset Station Qty 30.0
AM Preset Station Qty 10.0
FM Preset Station Qty 20.0
Antenna Form Factor Loop AM / wire FM
Response Bandwidth -14970.0 Hz
Signal-To-Noise Ratio 76.0 dB
Auto Preset Memory Yes
Additional Features Station naming , FM stereo/mono switch
Turntable
Type None
DVD/Blu-ray features
Type None
CD System
Type None
Digital Player (Recorder)
Type None
MD System
MD system type None
Display
Built-in display Fluorescent
Display dimmer Yes
Headphones
Headphones Type None
Microphone
Type None
Remote Control
Remote Control Universal remote control - Infrared
Features Multi-brand compatibility , Macro function , Learning
Miscellaneous
Timer Sleep
Power
Power Device Power supply - Internal
since my TV had the HDMI ports and switching built in I only needed to run digital audio from TV to the amp which worked out. $75 for red letters
