juicexj24 said:
if your getting power to everything and the thing has all the spark in the world. Check the starter relay. Mine went south in Nov. I replaced everything in the world with nothing more but wasted money. So if you get a turn over rule this out, if you crank it over and nothing happens. Have it replaced.
Just to clear things up... If its cranking, (spinning the motor) then that Itself rules out it being the starter relay.
The starter relays job is to supply your starter with power when you turn the key. The fact that the motor is spinning proves the starter relay has done its job.
Right now, my XJ is also in nostart condition.
It fires off a single cylinder every 4 or 5 rotations, 3 or 4 times and then won't fire at all.
87' with a 96' motor, Plenty of fuel pressure, Nice Hot MSD Spark, fresh tune up, oilchange, all new sensors.
I had a problem before with the connectors for the engine harness, (drivers side, above master cylinder 1/4 bold in center) if I had someone crank the engine and I smacked the connector, it would fire right up! Then, While it was running, I again smacked the connector and the damned motor killed...
So I figured it was the connector and did not worry about it too much. I planned on cutting the connector out and soldering all the wires and then heat shrinking them.
Tonight I cut out connector, and resoldered everything thinkin I solved the problem. But it still tried but no fire.
While trying to figure out what the deal is, I noticed my ballast resistor is SMASHED! Its on the firewall in the same location as the harness connector so I'm hopin that is what I smacked to make it run better. I didn't see anything else over there other then the MAP sensor that could have recieved the vibration of me smackin it. No loose wires...
Let you know but my moneys on that resistor..
