No power to interior no signal to obd2
Jamesxjrebuild
Hi so I have a 1999 jeep Cherokee sport 4.0l 4wd auto trans I recently did a full rebuild on the motor and took it completely out of the car I now have everything back in the car and I hook it up to the battery and I get nothing to the keyed ignition or any of the dash or front overhead panel but both the fuse boxes have power going to them all the fuses except for the ASD relay is staying an open circuit not allowing power to 2 of the mini fuses number 24 and 21 also not allowing power to the PCM I checked with a voltage meter and it has no voltage but if I jump the relay port even if I get power to it I still have no power inside the car other then the rear dome light I was wondering if anyone could help me out here I’m kinda at a loss other then going through the entire cars wiring and seeing what plugs have power and what plugs don’t
