- Columbus, In
Light came back on
Still getting Code 705 = Transmission Range Sensor Circuit malfunction (PRNDL Input)
Translated = the NSS
Problem is I have did the NNS fix, tested it and installed it correctly.
Code keeps coming back.
Man am I stumped :dunno:
Tested it how? On the bench with a meter? Is it adjusted correctly? Simple check for a gross misalignment would be to watch the backup lights as you move the shifter. If you're still getting the 705 code, then the TCU thinks there is a problem. It might be a wiring problem and not the NSS too.
Problem is Cured:
I got a new Digital Multi Meter and did some testing of the Trans Solenoids.
Turns out Shift 1-2 Solenoid was bad
I replaced all 3 Solenoids and my Rig is shifting Perfect
are your reverse lights back?
i had your exact same issue to a "T". no OD, no reverse lights, code 705. the only way i got it to go away was a new ECU/PCM or whatever you want to call it. i had previously tried everything everyone else already mentioned and none of it worked.
i picked up my PCM/ECU on ebay for 25 bucks.
I would check all your grounds to make sure they have good contact to the body. One could be loose and the trans is loosing the ground and and goes into failsafe mode.
i'm telling you man, you have the exact same issues i had, i would put money on the PCM
Are you talking the main computer under the hood that mounts to the fender well on the drivers side ?
I already replaced the TCM under the dash
