No gas no spark
Panama XJ
my 95 XJ don't start, it don´t have spark or gas pressure, I just changed the Crankshaft Sensor, the Cam sensor ande then realize that it don't have fuel pressure (the fuel pump is 3 months old), I checked all relays and fuses, please help.
Check your cps with a multimeter between the b and c plugs. it should show an open circuit or infinite resistance. If it shows anything else it is bad.
Also, try swapping your relays around, it could be the ASD relay.
when I had this problem it ended up the computer was fried good luck with it
