No Fuel= problem
family XJ
So far this is what I have done,
Put half tank of fuel in tank.
I replaced the fuel pump itself and the screen on the end of it.
Tried to start and no luck.
Took off fuel line at injector end, no fuel delivery when cranking over.
Put line pack on and took line off before the fuel filter, still no delivery.
I then checked the vent lines and they were clear.
I also disconnected the return line and blew through it and it was clear.
I can hear the pump running when the jeep turns over there just isn't any fuel coming out of the tank. I was told that the regulator isn't telling the pump to send fuel.
Where is the regulator located? This is on an '89 4.0 with 5 speed.
TIA
DuG
