Russ Pottenger
- West Covina, California
Use a JKS on the front. Unless Ya tow something. Rip the rear sway off and use it for yard Art to mount your Mail Box to.
elephantrider1 said:
bj-666 said:instead of putting the u shaped piece under the sway bar and the bolt going down into the disco slide the u shaped part over the sway bar so the sway bar is inside then put the bolt thru (you will have to have just the u shaped portion seperate whe you bolt it up )
elephantrider1 said:Well took the whole sway bar off tonight and i'm just going to leave it off. So if someone needs the jks quicker disconnects $50 and they are yours. Need a bolt for top piece cause they are bent but thats $2 at napa
bj-666 said:i don't get it are you guys just lazy or somethign. i mean how hard is it unclip the discos. sure the thing drives fine without the sway bar feels a little wierd in corners and all but what about and emergency manuver at highway speed. how many times have you had to whip it a land over to avoid and accident. without a swaybar highway evasive manuvers turn into a VERY dangerous situation.
i feel the same way, and i only have a 2" bb and don't like the body roll I get with out a sway bar.bj-666 said:i don't get it are you guys just lazy or somethign. i mean how hard is it unclip the discos. sure the thing drives fine without the sway bar feels a little wierd in corners and all but what about and emergency manuver at highway speed. how many times have you had to whip it a land over to avoid and accident. without a swaybar highway evasive manuvers turn into a VERY dangerous situation.
Budro74 said:Swaybars are for girls and guys named Sally.
