- MilkyWay Galaxy
Ok, replaced the CPS and it runs and has not died since I replaced that. I will replace the MAP sensor and the TPS. But what is IAC? I am sure after someone posts what it is I will feel like a idiot, but that one I can not figure out. Thanks for everyones help yet again, hope to get these problems ironed out before winter. And I dont want to keep spending money on all this stuff, there is a 4 1/2 inch Zone offroad lift kit that is calling my name, along with a set of 32 BF Goodrich KM2's. That will be the spring project.
Don't waist money on a MAP sensor, as they rarely go bad!!! Instead, clear the codes, and run it, and look for new codes. The vacuum tubing from the throttle body to the MAP sensor is known for coming loose at the throttle body and causing it to back fire during acceleration or deceleration. And it can go bad, and leak.
The IAC only affects idle speed control!!!!!!
Did you check and clean all the GROUNDS and Battery connections?????????
