Newer 97+ XJ in Turner U-Pull it
deisenba
Salem, OR
Just saw the post that was closed asking about a new xj in a u pull it yard. The yard in turner has a newer xj, but it is pretty picked over. It is the first one I have seen out there. They have some older xjs that have not been picked over too bad yet either.
Just thought I'd share the info.
does ut have a front clip?
Sorry guys, don't mean too sound sarcastic, but i didn't take an inventory when I saw it. I think it was hit in the front, but not sure. Maybe if someone local goes out to the yard, they can report back. I'm not planning any trips in the near future.
Where is this U-pull it yard exactly?
x2
Not all of us know what a 'Turner' is. If you're going to post something like this, can you give a location and MAYBE what you saw left of the Jeep? We're spread all over the place here. ;)
turner is a town about 15-20 minutes east of oregons capitol, salem, there were quite a few nice xj's there last time i was at u-pull, a cherry 2 door tub,a wrecked 2 dr, and 5 or 6 four-dours. i got some 297 shaft's last time i was there, and FYI- if the white limited cherokee with abs, and it is still sitting drivers side rotor down in a 4 inch puddle and large rock size gravel, there is a 297x inner and outer in there.
Sorry, I'll do a better job next time. And I was incorrect in saying it was U-Pull-It. It is actually Pick-a-Part. 6777 Turner Rd. Turner OR Phone #503-743-7425. They usually are pretty cheap also. Kind of been hit or miss recently though with their prices.
There was a post that I read after I was at the yard that was inquiring about new XJ's in the area, but that thread was locked, so I started a new one. The original poster was from OR, so I knew he'd know where Turner is and didn't think about the others that are reading the post as well.
And also, because it was after the fact, I hadn't paid much attention to the Jeep when I was there because I had no interest in it, I just noticed it was a newer one and I hadn't seen any yet.
They also seem to add new Xj's all the time. The current xj's will probably all be picked over and gone by the fall and a new crop will be in to replace them.
When you go out into the yard, the XJ's are in the NW corner. So when you go in, go straight till you get to the end of the row, and then right, past the Exploders till you get to the Jeeps.
Since it doesn't seem like too many people have heard about this yard, don't take all the parts I need. :)
I should get back out there before the rush hits.
