89 cherokee with the ba10.
last tranny started to crap out then all of a sudden it would drive around only in neutral as if it was in first. then it crapped out and the jeep would move unless clutch or xcase was in neutral.
so i swapped trannies out a 88 wrangler same ba10 minus a little difference in orientation.
replaced slave while i was in there cause it was leaking.
clutch and pressure plate are luk and less than 20k on them.
clutch master is also under 20k.
now it will move if i release the clutch as if i was in 1st or 2nd. but i cant get the shifter to move into different gears.
clutch is working because it will stall if i let go of it.
wtf?
only two thing i can think of is a or a bad pressure plate also replaced.
wtf?
