This is my plan for a Low Cost, Quality 4.5 inch XJ Suspension Short Arm Lift (Kit) for up to 33" Tires (35s with major cutting of Fenders and Regearing) for the New to Me, Late Year'96 XJ I will have in 2 Weeks; I have given a Deposit on it already. I have put a lot of thought and have done my Research on this. However, I am sure some of the product listed can be had else where made of better Quality at a Lower Cost. My Budget is $1500 for everything on this List Shipped to me.
Coil Springs
Front Bumpstops
Adjustable Front Upper and Lower Control Arms
Front Adjustable Track Bar with Double Shear
Adjustable Sway Bar Disconnects
Drop Pitman Arm
Nitrogen Gas Shocks
1.5/2.5" Shackles
Stainless Steel Braided Brake Line Kit
Leaf Springs
SYE and Driveshaft
Rear Bump Stops
If anyone knows of anything that is of the same Price and of better Quality, please Post Up.
If it is of same or better Quality and better Price, please Post Up.
No matter what it is, if it's a better Deal and will work on this Lift, please Post it up.
As usual, any and all Constructive Comments, Ideas, Alternative ways to achieve my Goal within the same Budget ($1500) are always Welcomed and Appreciated.
Thanks,
cher96 Vicki
Coil Springs
Clayton 4.5 Coil Springs (pair) 84-01 XJ-Front $149.00
http://claytonoffroad.com/product_info.php?cPath=18_73&products_id=164
OR
From Iron Rock Offroad
XJ 4.5" Front Springs with Lifetime Warranty $129.99
http://www.ironrockoffroad.com/Merc...en=PROD&Store_Code=IROR&Product_Code=IR-X4FSP
Front Bumpstops.
Using Bump Stops at the bottom of the Coil Spring instead of Extended Bump Stops at the Top will work better than having the Extended Bump Stops break off or get caught in the Coil Springs IMHO.
Hockey Pucks $0.99 each
http://www.epuck.com/regicehocpuc.html
or
RE Bumpstop Kit $32.95
http://www.rubiconexpress.com/Jeep/XJ/Products.aspx?folder=XJBS
Adjustable Front Upper and Lower Control Arms $249.50
4.5"s of Lift: Stock Uppers at 15"s of Length are fine for Light Offroading, however, Adjustable Uppers should be Set to 15 1/8"s and Lowers to 16 3/8"s of Length.
http://www.ironman4x4fab.com/Jeep_XJ_Control_Arms/XJ_FULCA.html
Front Adjustable Track Bar with Double Shear Kit $159.50
A Double Shear Kit converts the Factory Bracket to Double Shear Mount at the Track Bar.
http://www.ironman4x4fab.com/Jeep_XJ_Track_Bars/XJ_FTB.html
Rock Krawler Front Adjustable Sway Bar Disconnects $106.95
http://www.discountjeepparts.com/pr...27443?osCsid=8c7f7795cfbe55716b9790ac65c8d682
Drop Pitman Arm $39.95
http://www.4x4groupbuy.com/store/drop-pitman-yjtjxj-jeep-re2500-p-2590.html
4 to 6" Lift 9000 Nitrogen Gas (Nitro) Shocks
Nitro 9000 (9000 Nitrogen Gas Shocks ride better than Hydros IMHO) for Lift Height.
4 - 6" 9177/9178 http://roughcountry.com/shocks_jeep.html
or
Doetsch 9000 Nitrogen Gas Shock (Custom Fit) $48.65 each
http://www.shocksandsuspension.com/productinfo.asp?item=2&dc=1
1.5/2.5" Shackles: RCX ($49.95) will do with Greasable Spring/Shackle Bolts w/ Sleeves or Boomerang Shackles (much more Expensive).
The Longer the Shackle (I do NOT suggest any longer than 2.5"s of Lift) the more Flex will be Acheived with proper Shackle Angle. It will allow the Leaf Spring to Elongate (stretch).
http://roughcountry.com/jeep_xj_shackles.html
http://www.xtremeterrain.com/cherokeexjshackles84-01.aspx
and Shackle Relocaters if needed: http://www.naxja.org/forum/showthread.php?t=1004504&page=2
XJ Stainless Steel Braided Brake Line Kit $99.99
http://www.ironrockoffroad.com/Merc...en=PROD&Store_Code=IROR&Product_Code=IR-XSBLK
U-Bolts: Auto Zone
Leaf Springs
I would never go with Add-A-Leafs again. They usually Flatten Out in just a few months. Mine did.
Many Jeepers have had some problems with Axle Wrap and other Issues with the Cheaper Lift Leaf Springs.
BDS Leaf Springs have a Lifetime Warranty and Fantastic Flex. They are a little more but worth the cost in the long run.
http://www.bds-suspension.com/php/Order_by_pn.php
004209 (2) Jeep XJ 3" Rear Leaf Spring $380.12 $190.06 each
or
Bastard Packs http://www.naxja.org/forum/showthread.php?t=1004504
Transfer Drop Kit, SYE, and Driveshaft
You do not need a Transfer Drop Kit if you do a SYE and Driveshaft. You can keep your TC Clearance this way.
However, if you do have Rear End Vibration then here is a solution that will work until you have money for a Heavy Duty SYE and Tom Woods Driveshaft.
Great Thread on doing a J Yard SYE and Front Driveshaft:
http://www.naxja.org/forum/showthread.php?t=959008&highlight=SYE+yoke
Iron Rock 4x4's SYE and Front Driveshaft:
http://www.ironrockoffroad.com/Merc...en=PROD&Store_Code=IROR&Product_Code=IR-X_HNT
Here is their PDF on doing a SYE and a Front Driveshaft.
http://www.ironrockoffroad.com/Merchant2/hack and Tap Install.pdf
Rear Bump Stops: Iron Rock 4x4 Truss with 2" Bumpstop Pads. Strengthen the Axle Tubes while adding Bump Stop. $99.99
http://www.ironrockoffroad.com/Merc...en=PROD&Store_Code=IROR&Product_Code=IR-XD44T
That's pretty much it for Suspension. I am so very much excited about Building another XJ!
Hope this Thread will help someone else interested in doing a 4.5 inch Lift on their XJ.
Anyone have any helpful Insights, Thoughts, Ideas, or other comments?
Thanks.
cher96 Vicki
Coil Springs
Front Bumpstops
Drop Pitman Arm
Nitrogen Gas Shocks
1.5/2.5" Shackles
Leaf Springs
SYE and Driveshaft
Rear Bump Stops
Thanks,
cher96 Vicki
Coil Springs
OR
Front Bumpstops.
or
or
U-Bolts: Auto Zone
Leaf Springs
or
mine is a combination of stock xj's, and two leaves from a 3/4 ton dodge pickup. good for 3.5-4" lift, and
rides better than stock.
Maybe, those Leaf Packs came from one of these?
Years Description....................................................# Leaves..Width..Measures (A*B)...Spring Capacity
73-93 Dodge Pickup/Plymouth Trail Duster (1/2" bolts)....4/1.....2-1/2.........24*28..................1650
73-93 Dodge Pickup/Plymouth Trail Duster (5/8" bolts)....4/1.....2-1/2.........24*28..................1700
73-93 Dodge Pickup/Plymouth Trail Duster (5/8" bolts)....5/1.....2-1/2.........24*28..................2500
Hope this helps.
It's the van leafs 70-96 if memory serves me.23x30.5or31.
This is the start of my next pack! Add the shackle relocators mentioned her and I understand it's a great
ride.
Here are some Dodge Van Leaf Packs also.
Years Description...................................................................# Leaves..Width..Measures (A*B)...Spring Capacity
70-97 1/2 Ton Van......................................................................4.............2-1/2......23*31..................1200
70-97 1/2, 3/4 Ton Van.............................................................4(3/1)......2-1/2......23*31..................1600
70-97 1/2, 3/4, 1 Ton Van (1 Ton with Side Bar Shackle)...5(4/1)......2-1/2......23*31..................1800
70-97 1/2, 3/4, 1 Ton Van (1 Ton with Side Bar Shackle)...6(5/1)......2-1/2......23*31..................2500
72-97 1 Ton Van with One Piece Shackle.............................7(6/1),,....2-1/2......23*30-3/4...........2750
72-97 1 Ton Van with One Piece Shackle.............................7(6/1)......2-1/2......23*30-3/4...........3250
Here are two different Budget Build Write Ups with 2 to 2.25" Bastard Packs within.
The Home-Brew 2″ Budget Boost Page is an Excellent Write Up for doing a 2" Bastard Pack Lift. It has all the Info and Photos on the "How To" that anyone would ever need IMHO.
FitchVA’s Home-Brew 2″ Budget Boost: http://fitchva.com/jeep/?p=56
Here is the other Budget Build by Martin Verburgt with a solid 2.25"s of lift:
http://www.rocklizardfabrications.com/home_brew_budget_boost.htm
Thanks.
cher96 Vicki
