onetallmj
- San Bernardino Ca
Well I had a shop put my stroker(4.6) in my MJ and took it home today.
Its a basic 4.6 with the Comp cam and regular pistons( no dish) so the compression is probalby high. Anyway the problem is that on the drive home when the gas pedal is pressed there is a lull and it backfires but if you really give it the gas it goes fine.
I was planning on checking the MAP and all the other sensors to make sure their hooked up correctly. Anything else to check? It idles fine but took longer than normal to start up. Maybe build an ajustable MAP? How can I check the air/fuel ratio at home with no gauge?
thanks
thanks
