new steering ?
mgt
NAXJA Member #653
Riverside
how can i make my sterring stronger or should i just buy a stronger sterring system if even possible? I have a 6" lift w/33's and a new trak arm. all orgs stuff.
Yes. I'm asking because the bolt that goes from the tie rod to the bar ( i don't know what it is called) that goes to the pitman arm is getting loose.
the hole in the tie rod is getting bigger as it wears.
OK, It's where the drag link bolts to the tie rod. Is there a stronger drag link and tie rod i can get ?
Currie sells a nice setup. Try searching, there's a few threads on this very subject:)
